TwinTurbo.NET: Nissan 300ZX forum - Hardware dimensions are not in the manual. (n/m)
on October 29, 2016 at 5:28 PM
Follow up Q: Are the dimensions of the screws readily known?
posted by mysticLegoZ
on October 29, 2016 at 04:41 PM
Turn signal housing removal (with stripped bottom screw)?
mysticLegoZ
10:51:09 10/29/16
Re: Turn signal housing removal (with stripped bottom screw)?
itsa300zx
11:23:23 10/29/16
Same (n/m)
-Grimm-
15:02:29 10/29/16
Thanks, prying while unscrewing worked...
mysticLegoZ
16:34:12 10/29/16
mysticLegoZ
16:41:10 10/29/16
Same as the passengers side.. (n/m)
ttz'in (norcal)
17:11:51 10/29/16
Hardware dimensions are not in the manual. (n/m) -
17:28:36 10/29/16
Realized as much after looking through the documention...
mysticLegoZ
19:49:37 10/29/16
It's not supposed to be black - they are stainless.
20:11:48 10/29/16
Per the hardware store, closest match was a #8 x 1-1/4 in...
mysticLegoZ
15:21:23 10/30/16
If it's the plastic that's damaged...I use plast-aid to fill
white22sky
18:08:53 10/29/16
Thanks, good to know. (n/m)
mysticLegoZ
19:50:55 10/29/16
*re-thread (n/m)
white22sky
19:57:40 10/29/16
